It is currently Sun Sep 14, 2025 8:05 am
PostPosted: Wed Jul 20, 2016 3:16 am
First name: Aaron
I don't normally post builds, but since I VERY rarely do hardwood tops, I thought I'd share one that's following my recent direction of "simple", but not necessarily easy.
And here's a sample vid.
https://vimeo.com/175416845
PostPosted: Wed Jul 20, 2016 8:30 am
Lovely golden hues! Well done on the uke, too!
PostPosted: Wed Jul 20, 2016 12:33 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Gorgeous ukulele. That Koa is stunning
I'm not sure I'd call anything with a bound headstock "simple". That's just tastefully understated
PostPosted: Wed Jul 20, 2016 1:04 pm
Nice tone! Do you know how the audio was recorded?
PostPosted: Wed Jul 20, 2016 2:23 pm
First name: Aaron
Thanks guys.
Pat, Andrew records it "dry", in a room, nothing special other than his mic, which I believe is a good condensor. You may be able to see it if uou search Vimeo for Hawaii Music Supply.
Ukulele Friend also does good audio samples, with the vid shot in the studio.
PostPosted: Wed Jul 20, 2016 3:08 pm
First name: Aaron
You know, it took me a LONG LONG time to figure out how to effectively, accurately bind the headstock and fretboard, when there is no gap because the nut is in the fretboard.
Suffice to say, besides the bwb purfling miter, I need to "make" the headstock binding go "into" the fretboard binding. I'm getting better at pulling off that joint.
PostPosted: Thu Jul 21, 2016 6:23 pm
First name: Aaron
Update on the recordings: Stereo pair of Shoeps CMC6.
These users thanked the author Aaron O for the post: Pmaj7 (Fri Jul 22, 2016 12:02 am)
PostPosted: Thu Jul 21, 2016 7:03 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Wonderful looking ukulele. Inspiring for me; your choice of trim woods, your bridge design, your head stock design and the attention to detail throughout really set your work off.
PostPosted: Thu Jul 21, 2016 10:39 pm
First name: Aaron
Thanks John. "Inspiring" is a heavy word, much appreciated.
And I recently redid my bridge to a much simpler design, without negative effects as the footprint is a little larger than what I used to do.
I know Andrew does a good job of showing the wood with his pics, and not highlighting the glare. Oddly enough, in not showing the glare, the images don't show how much work was done to gloss the finish. I think the vid shows it a little, but even then, you can't really tell.
Just realized, and nobody asked, but here are the specs:
Top/back/sides. Koa
Neck Spanish Cedar, Mortise & Tenon bolt on, Carbon Fiber Rod
Binding Rosewood
Bridge. Rosewood
Fretboard. Milo
Markers. Mother of Pearl
Rosette. Paua Abalone
Nut/Saddle. Tusq
Tuning Machines Hipshot closed geared
Finish Cardinal Gloss Lacquer
Strings. Savarez Alliance Normal Tension
PostPosted: Fri Jul 22, 2016 7:47 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Beautiful instrument! The rosewood binding looks great with the koa and I like your headstock shape. I've never seen a nut arrangement like that before. Is the piece of milo north of the nut a piece that's separate from the fretboard, or is the nut sitting in a recess in the fretboard?
It sounds great in the video and the audio quality is excellent. I looked up the mics and those are way more than I could justify, but they sure do record a nice sound.
PostPosted: Sat Jul 23, 2016 12:07 am
First name: Aaron
Jay, you actually have seen a nut like that, more than likely - Fender.
There was a small discussion on the Underground about what this "solves" from a finishing perspective when the nut ends up between the fretboard and headstock veneer.
Truth be told, I didn't want to copy Fender, but oddly enough, most people don't make the connection. And the discussion was small because anyone who finishes an instrument where the nut goes in between the fretboard and headstock immediately knows the pro's of doing it like this.
Yours is the 2nd comment on binding, yet its the first time I've used Rosewood; I usually use Milo, or Koa (mostly). I have more that maybe I'll have to keep using.
PostPosted: Sat Jul 23, 2016 12:25 am
First name: Jay
City: Bothell
State: Washington
Ok, you got me there. :oops: I just went and looked at my Strat and sure enough....
I blame my failure to recognize it on the fact that on yours the nut ends are inset from the edges of the fretboard and the binding is visible from the top where it passes the nut. Even on Fender necks that are bound, the nut goes all the way to the edge.
PostPosted: Sat Jul 23, 2016 12:51 am
First name: Aaron
I was just about to comment the reason mine may look different because I run the binding on the outside.
If you do the "math", it has standard string spacing. This means the fretboard is actually wider than "standard" by about 1/8" (binding is about 1/16"). Yet, most comments about playability is "easy" and usually never anything about the width. In fact, I've had a few players try to figure out what makes it so easy to play. Fun stuff!
These users thanked the author Aaron O for the post: J De Rocher (Sat Jul 23, 2016 2:32 pm)
cron
